Recommend a 800Mhz Base Antenna
Dubbin
Findlay Ohio
Can someone recommend a good 800Mhz base antenna? Im not looking for any kind of a beam since the two towers I am wanting to hit are in opposite directions. I already have a scantenna but its just not cutting the mustered for what I want. I also do not want to spend a fortune on it with the holidays upon us.
K5MAR
Stillwater, OK
Well, in absence of any better advice, I'd suggest you make one. You have a couple of options, fabricate a ground plane antenna, starting with one of the 1/4 of 5/8ths wave mobile antennas that are readily available; or a frequency-specific discone.
Sorry I don't have any plans ready to hand, but a Google search should turn something up.
There is/was somebody who made 800 MHz antennas, the most commonly seen model mounted on a handheld scanner, but I recall they made others.
Sorry I wasn't of more help,
Mark S.
LarrySC
Greenville, SC
There is a MAXRAD 800 23" dual open coil 5db gain antenna at this site. The antenna is a mobile using a MAXRAD base adp. Motorola NMO mount and hardware. Coax end can be F, BNC, or N. Stock num 2-2067 plus mount. www.bncantenna.com
doctordave
I used one of Larry's high-gain 800 MHZ antennas, with home-made base radiators & a short (15 ft) run of rg-6 and was quite pleased. Ended up shifting to a yagi due to intermod troubles....but unless you are surrounded by Nextel, etc, you'll be quite pleased.
Dubbin
Findlay Ohio
Larry I dont see the mount for it. It dont come as the picture of it shows?
W4KRR
Coconut Creek
Dwayne, I once made my own 800 MHz base antenna. Basically, I just got an 800 Mhz 3db gain mobile antenna, and mounted it in the center of an 8 inch diameter aluminum disk. I made a "pigtail" by cutting off the small mobile coax about a foot from the base of the (NMO) mount, and installed a type N female connector. I fabricated an "L" mounting bracket and fastened it to the aluminum disk, and mounted it atop my tower. I fed it with low loss coax with an N male connector at the antenna. I used it for many years, and it worked very well.
JohnWayne
Lynchburg, VA
Nothing beats a real 800MHz base antenna for listening to 800MHz at your base. This includes jury rigged mobile base converter setups, homemade antennas, etc. However, you have to pay a little more if you want this level of performance. You will be rewarded with excellent performance however.
I sell quite a few base antennas to people who are serious about 800MHz monitoring, and they are all nothing less than pleased with the results. I invite you check out our selection of 800MHz base antennas and see if there is something that fits your price/performance budget.
Please do let me know if you have any questions.
Thanks!
Jeff
Dubbin
Findlay Ohio
Ok Duke Ill check them out :)
Bet thats not the first time you heard that one :)
JohnO44
Trumbull
Did anyone mention a 8 element Yagi avail from "The Antenna Guy" for about $90 + shipping.
I put one up 20ft w/ 9913 coax and got 3 more bars on the S-meter on my BC296D.
