Recommendation for a decent magnetic mount scanner antenna
Jphila20
Retired LE. Honor our Fallen.
Southern Lorain County, Ohio
Morning All.
My mobile scanner antenna after many, many years of use, I had the whip snapped off. What antenna do you use and for your mobile scanner?
What would be considered a decent mobile antenna for a TRX-2.
Thanks!
John
The antenna is the most important part of your setup and getting a good one pays off in the long run.
You can't go wrong with these, and I've used both extensively on multiband mobile transceivers:
Running this one on my work truck:
Running this one on my personal truck:
If you don't need the spring base and want to save some money, this has received some excellent reviews and will likely outlast your car:
If you need a magnetic mount, pair it with a decent quality NMO mag mount with the correct connector to match your radio:
Jphila20
Thanks! I'll check them out.
There are few PDs still using VHF around me, but must are UHF trunked.
prcguy
This is probably the best deal in a triband VHF/UHF/700/800 commercial mag mount antenna right now.
