Mobile Scanner
Hey
I run the Iowa City feed here on RR. If you're getting a mobile for your car, you'll want the BDC996t, or 996xt scanner. Right now, Iowa CIty and Johnson County are Analog, but as of July, they're going digital. So any analog scanner you cant now wont work. The 996 Uniden scanners are both digital.
They also come with a DIN sleeve, so if your civic has a standard DIN slot for the stereo unit, you can actually just slide the scanner into the slot.
THey're also both programmable from computer. The readio system in the county is going to get complicated when it goes digital. There's going to be hundreds of talkgroups, channels, and codes etc. You'll want to be able to program the scanner and lockout unwanted channels from the computer. Otherwise you'l spend hours spinning the knob and pushing buttons to program the scanner the slow way.
Check ebay for good deals on the Uniden BCD996t /xt scanners.
