ScubaJungle
Recommendations: Antennas for 406mhz Mil & 160-220mhz Federal/Milair - What do you use/recommend?
I would like to expand my scanner interests and get into fed/mil/milair monitoring, and am looking for a 400-410mhz antenna for military, that will outperform the stock rubber duck on BCD436HP, which performs well for 800mhz and decent all around, but I'd like to extend my range on 400mhz and get this system/have a dedicated antenna. I also have a signal stick: Super-Elastic Signal Stick
which is good, but:
I am just out of reach of a nearby 406mhz system that is ~20miles away. I can unreliably pick it up with my SDR (sdr blog v3 with kit antenna) in good conditions & get 60-75% of transmissions, but cannot get it on the BCD436HP at all, even with the blog v3 kit antenna. (it isn't simulcast)
I'd also like to improve my range for the federal frequencies/mil air (160mhz-190mhz federal & milair), some of which I also can unreliably get in good conditions.
I have been looking at these, below, since I can extend the antenna for 160mhz and shorten for 400mhz, but I'd like tips and recommendations regarding what the best plan would be, even if that means two separate dedicated antennas.
Does anyone have antennas they use for these particular purposes that they can recommend? I am not opposed to having two separate - 406mhz / 130-230mhz antennas if it will increase my reception a decent amount. If one will do the job for both, then obviously that would be good, but I'm looking for reception efficiency #1 over convenience.
I'd prefer something handheld/mobile, as I just got an 800mhz yagi and a discone, but if a base antenna is the only thing you think would do what I need, please feel free to recommend them.
Tl:dr
-What antenna do you guys use/would you recommend for 400-410mhz?
-What antennas do you guys use/would you recommend for 160-220mhz (VHF - federal & milair)?
Thank you!
which is good, but:
Tl:dr
Thank you!
