Gadgeteer2000
Hello all,
I am looking for recommendations (ideally sub $100) for an attic mount antenna for receiving only. (I know attic is not ideal - but cannot mount outside).
I am in a rural area (about 30km from Toronto) so need a reasonable antenna to get some signals in. Also, my house has quite a bit of RF noise (solar panels, LED lights etc.)
I am considering a Tram 1410 Discone in the attic, in a spot that is farther away from the solar panels: is that recommended?
Or would you have other suggestions? I could install a LNA directly next to the antenna - is that a good step to take?
What cable should I use to ensure a high quality signal to arrive at my SDR receiver (which is about 5 m away, in the room directly under the attic spot where the antenna would be)?
I am quite a newbie with this - so any suggestions would be greatly appreciated. Thank you!
