ProScan: Recording Issues
etimothyd
Nova Scotia
No audio recorded, if someone else signs onto pc. everything gets logged and a file is created but it is blank.
Can anyone confirm this, or do you not have to share your computer.
I think it must be the primary sound capture device. Does anyone know how to get around this or do I need another pc?
I guess this is more of a computer question.
lamarrsy
Rimouski, PQ, Canada
When you installed the software, did you select “everyone on this PC” or “just me” when prompted by Windows install (it is not specific to ProScan, it is a Windows procedure usually used on standard installs) ?
It may be obvious but, just in case : you do have an audio cable connected from the scanner to the PC ?
In the “Audio Control” tab of ProScan, check that your « primary sound capture » input is selected and that you see the waveform when the scanner has audio (do a test with a weather channel).
‘Let us know the progress in your troubleshooting !
