RECORDING SCANNER CONVERSATIONS
Colin9690
County 21
APE282018
Hi,
I would like to know how to hook the scanner up to your computer, and when the scanner is on, it records the audio to the computer. Can u tell me what I need to do this?
Thanks,
Colin
DaveH
Ottawa, Ont.
It is very easy. Get some free scanner recorder software,
install, and hook your scanner line output or speaker/headphone
jack to the sound card input on your computer (usually the
line input). The recorder is VOX-triggered so you don't
waste disk space with long periods of nothing. Here is
one good site (there are others):
http://www.davee.com/
For scanner audio, you can set the recording to mono/8KHz
which is more than good enough, and keeps disk usage
down.
Dave
mdulrich
Van Wert, Ohio
KCChiefs9690 said:
what kind of cable do you need?
Just a regular audio cable with ends that match the scanner and audio card. Probably they will be 'minature' ends.
Mike
