Recording software
daredevil1
Is there any recording software similar to ProScan for the Unication? Or what's the best way to record to a computer without having to backup the messages everyday? Thanks
daredevil1
Nobody? I'd much prefer using this for software logging than the SDS200, as the SDS misses the beginning of transmissions sometimes.
N6ML
If you can get the audio out (e.g. through the amplified charging base, or BlueTooth), you can use whatever you want to record it ... but there is no interface (that I know of) for controlling the G-series pagers via software, so software would have no way to do things like determine which channel traffic is being received on during scanning.
IAmSixNine
Dallas, TX
I have a G4 providing a private feed for me to listen to while im at work.
I use ProScan software and the G4 is in the amplified charging dock. I use the speaker out to input into the mic of a USB audio dongle.
So i can listen to it live and it records files to the computer.
daredevil1
So you just use the VOX feature?
daredevil1
Correct, i use VOX to start and stop the audio recording features.
Well I purchased the dock. It's cutting off the end of thr transmission when I put it in the dock. Is there a way to turn off buffering? That option is greyed out once I put it in the dock.
IAmSixNine
Dallas, TX
What version of firmware is in your unication?
Are you sure its the pager cutting off the end of the audio and not a VOX setting?
