RedPenguin
- Joined
- Feb 28, 2007
- Messages
- 1,082
Alright, to explain what I want, I will explain why I want it this way.
I occasionally have special events in my area which produce a pretty darn good amount of radio traffic.
Though normally there isn't a huge amount of traffic in my area, so normally I use a Vox-type Recorder, such as XCorder and Vox2File.
Now one thing I did notice about Vox-type Recorders is that they seem to work for the most part, but some Vox Recorders I have had, not XCorder or Vox2File, have ended up screwing up on tons of traffic.
So I would like to use a continuous sound recorder as well just in case. If I end up not needing it, I can just delete it. I never tested my recorder PC under heavy traffic.
For continuous sound recording, I have always used Audacity, though the problem that I see is that, because the traffic can easy go on for 8+ hours, Audacity may take an hour or more to export to mp3.
My big question is then, is it just safer to go with the long export of Audacity or just opt for a continous recorder that just constantly records directly to mp3?
Plus, after reading the Wiki on setting up your radio scanner to your PC (yes, I've already done it, but figured maybe I would get some tips), I noticed they said if you have a constant hum you may want a Group Loop Isolator. Like the one from RadioShack.
Is this the sound they are talking about?
http://adam.250free.com/noaudio.mp3
Note:I get this sound when I hook up my BCT15 or BR330T to any computer.
