do you have a computer controlled scanner already? regardless, you can do this using any scanner. Just have a cable from the speaker output to the line-in on your soundcard. Then just use the MS recorder to record, although it only will do 60 second clips. But if you get your hands on TotalRecorder, you can record as long as you want.
