Recurring error 06/10 on w3 head
cjradloff76
Hi, I have an issue with my w3 control head it said 06/10 and won’t go away
Not all buttons work
Vol is mode
Mode is channel change
Ptt works
Nothing else
It only happens on 1 brick
I tried it in another and I get a 1 in the display and it does nothing
Any ideas
Please let me know thanks clint
MatRat80109
Colorado
For an XTL 06/10 is listed as a non-fatal "Aux control head failure". The error chart has the corrective action of power cycling the radio.
If a couple of power cycles doesn't clear it the head may have released the magic smoke.
R/MR
a417
U+0000
W3s that respond the wrong way to button presses (specifically mode & vol) usually have the wrong TIB, IIRC.
Which TIB do you have?
a417
U+0000
W7 and 03
Those are control heads, your issue likely lies between them and the radio body.
What are the model numbers on the TIBs/CHIBs you have?
I'm screenshotting a very pertinent section from the valuable website that W9CR has hosted, the pic I posted above I believe (if ebay can be believed to be reliable, heh) that it's a HLN6883A. If the model number on your TIB starts with an H, it's not compatible with an O3, you can see that below.
