Red (c) are control channel ?
LB_Scan
Hi
When I program my trx 2 scanner, it dose not show the other frequencies. Only show Red (c) are control channel capable frequencies.
Like on
1 (1)001 (1)LAX460.100c460.550c472.550472.5625472.5875472.6375
1 (1)002 (2)Van Nuys472.550c472.5625c472.5875472.6375
1 (1)003 (3)LAX 700769.11875770.76875771.13125771.19375772.31875773.21875773.46875c773.70625c
774.20625c774.45625c
1 (1)004 (4)Van Nuys 700769.58125770.58125771.08125c772.13125c
thanks
GTR8000
NY/NJ Database Guy
BEE00
If you're asking why only the control channels were imported, that's because by default most scanners only need the control channels for P25 systems. They determine the voice channels on their own using the band plan that is broadcast over the air.
jaspence
Michigan
You can program other frequencies individually, but then you lose tracking. Usually individually programmed frequencies are in their own list.
