RED Center Changes
N9JIG
Sheriff
Moderator
Far NW Valley
RED now has a new license (WQUF682) that points to how things might shape up after Park Ridge and Des Plaines joins.
155.7975, located at Lincolnwood and 155.4375 located at Des Plaines, will likely simulcast each other with an input of 153.8675.
This could portend to a realignment into North and South operations. If so Lincolnwood would likely join with Park Ridge and Des Plaines. I would think that North Maine, Niles and Morton Grove would probably go South also.
Other towns would likely stay on the 159.660 and 153.215 repeaters.
Again, this is only a guess at this point.
Park Ridge already uses RED numbering, Des Plaines will use Stations 61 62 and 63 for front line equipment and 64 and 65 for reserve.
PR and DP should be on line at RED sometime this year.
dchamp68
Chicago, IL
Rich,
Your information is correct. The final determination of who will be in the South group has not officially been decided but will most likely be the way you have it. Tentative cut over date for DP/PR was August 1 but I don't believe that is realistic at this point.
