getitfixed
I took my pro 106 back cover off to check the screw to see if it was tight it was and then i seen this red screw and turned it to tighten it and then seen it's not to be tightin.anyone know what that red screw is
If it's the red screw in this post http://forums.radioreference.com/gre-scanners/85155-psr-500-discriminator.html you adjusted a trimmer cap which may cause a slight frequency shift.yes it is working but it looks like it migth be a setting of some kind
Haha! Reminds me when we used old tube type taxi and police radios. Some guy would bring one in and say, "Gee, it was working great until I tightened a couple of those little screws". --- DUH!If it's the red screw in this post http://forums.radioreference.com/gre-scanners/85155-psr-500-discriminator.html you adjusted a trimmer cap which may cause a slight frequency shift.
yes that is the red screw thank you fmon. how do i reset it. I new better but did it any way. So what should i do thank youIf it's the red screw in this post http://forums.radioreference.com/gre-scanners/85155-psr-500-discriminator.html you adjusted a trimmer cap which may cause a slight frequency shift.
You sent me an email which I replied. But did not suggest a fix yet. Let me know the top bar indicators are compared to previous use while scanning a TSYS.yes that is the red screw thank you fmon. how do i reset it. I new better but did it any way. So what should i do thank you
Here's what I would do: (If it's still receiving well, I would leave it alone)yes that is the red screw thank you fmon. how do i reset it. I new better but did it any way. So what should i do thank you
Thank you all for your help. I think i will try the weather station cause when i turn my attenuator on it does not lose the signal bars like it did before. So i will try that and let you all know. and again thank you all for helpHere's what I would do: (If it's still receiving well, I would leave it alone)
If you are determined to get it back to where it was, try this.
Look closely at the red screw. If it NOT inside a coil, this MIGHT work. No guarantees.
1. Set it on manual and tune to a weak, even noisy, weather station.
2. Note the exact position of the screwdriver slot. BE PRECISE.
3. VERY SLOWLY, turn the screw to the right (clockwise) until you lose the signal.
4. Note the exact position of the slot.
5. VERY SLOWLY, turn the screw counter-clockwise until you hear the signal again.
6. Continue turning the screw counter-clockwise until you lose the signal.
7. Note the exact position of the slot.
8. The correct setting should be mid-way between the points where you lost the signal.
Hope you get it fixed.I will try and let you all know.
:wink:Hope you get it fixed.
What was wrong with the scanner in the first place?
Did you hear some sort of rattling that made you curious?
