wb6uqa
Turn off electricity to your house. Listen on battery receiver. Make sure noise is coming from your house. Buy a radio like a IC 7300 with good noise blanker.If noise comes from your house turn circuits off one at a time.
You said you had a wire about 10ft high and 45ft long - but how do you get the signal into your house? I have two Off-centre fed dipoles (OCFD) almost in parallel above my roof but the feed point has a 9:1 RF transformer then coax down to the receivers almost underneath - this is an old pic that only has one OCFD. The transformer has the effect of cancelling out any local low frequency interference picked up by both legs but not cancelling the HF signals - and also matches the high impedance of the antenna to the low impedance of the cable and the radio/multicoupler.
I think you might find as you go around your house there will be some motor or switch mode power supply that is making most of the noise - try switching them back on one at at time.
I wouldn't worry too much about an earth system not complying with the NEC requirements and voiding your house insurance in case of a claim - if your antenna is struck by lightning most of the evidence will be vapourised!
Reviewed some posts but not finding what I need and this was difficult to find the right forum to post in since it covers alot, I figure you HAMs are the pros so here goes my situation.
I been SWL and Scanners off and on for a long time I enjoy HF alot and never had a proper antenna up due to some kind limitation. I will soon join in and be a Ham myself so now I m revisiting the issue of RFI/Noise floor and I want better. The issue: I have always been playing with a noise floor of about -80db to -90db in SWL I do my best and deal, I do okay but always had trouble getting those weaker ones in. I watch videos of others enjoying -100 to -120db and then again I see others where I am at more or less so I am unsure where I stand.
Is there really anything I can do to improve the noise floor for me?. Im not knowledgeable yet like most in radio so I can use some help I will continue my living situation,what I know and done so far.
Situation:
I live in north Texas near OK small town but decent size, old house and I mean old, old wiring, all is still two prong outlets. I have now a temp long wire outside my window to shack about 10ft up about 45' for HF. I had higher wideband & HF up at 25ft with no major difference. I am in process of ordering items & redoing all antennas and experimenting since I hope to also TX in a few months, but I am very limited in antenna location and config so trying to be creative.
What I know:
My house atm is not electrically grounded to the rod. Yeah I know I just felt you all slap your hands to your foreheads. I just discovered this and will have it shined up and new connector put on looks like the connector got old, corroded and broke off. Not sure if this will help my problem but needs to be fixed.
What I done:
In a effort to see if anything in the house is doing me harm I used a portable radio on AM on no station to see if I can get buzzing from areas of the house. I discovered a desk lamp which caused some RFI and its gone, LCD monitors in the shack some but cant change that. Router/Wifi but cant change that. They are causing some RFI but not effectng the noise floor that I can see. As far as I can tell I cant find much else with this method. I have RFI that I can see on my SDR displays that maybe external but we all get that on HF just not sure how bad it is for me.
Grounding plans:
On top of fixing the house ground to rod, I plan to have a electrician properly at least ground my shack in the house with true ground and 3 prong outlets as well and possibly a rod outside the shack and bring in ground thru the wall for a ground bar for equipment grounding.
Thats about it, not sure if I can improve things, it maybe just current conditions just dont have enough experience to tell.
Any help and advice appreciated.
Frustrating isn't it. Tracking this stuff down can be tedious.
Anyway, several things: perhaps as you suggested you missed something that is still on the circuit after you thought every thing was unplugged. Go around the house with a portable AM radio tuned to a frequency between stations so that you hear just the noise. Use the portable radio as a direction finder and hopefully locate the noise source. Also, as you mentioned, funky wiring may be the culprit. There may be a loose bad connection somewhere on the circuit that is arcing. Again, the portable radio will track this down. Another thing to consider is this; maybe you did unplug everything and maybe the wiring is OK but that circuit is acting as a giant receive antenna for noise from outside the home. When you switch it back on, it couples the noise into the rest of your house wiring.
Switching various house circuits in and out can produce results that will have you scratching your head. Typical house wiring is unshielded and it can easily pick up and re-radiate noise.
Meanwhile, do some more detective work with the portable radio and see what you can find.
I agree with the last part that switching in a circuit can route noise to that area. Is the area most affected by switching the breaker back on near the antenna by chance?
prcguy
prcguy
