Recently, I was on the hunt for a desktop scanner for my desk at work. I didn't need anything new or high tech since this would just be for casual listening to the VHF local and wildfire comms, area ham and GMRS repeaters, ATC, NOAA, etc. I love old radios, especially Realistic/Radio Shack, so I began hunting for an old RS scanner that I could turn into a little low-budget project and keep an old radio in service. I found a Pro-2021 locally on Craigslist for $20. It powered up and received ok, but the pots were scratchy and it was kinda dingy looking:
I'm definitely not a skilled electrical engineer so finding a scanner in good working order was important. I popped off the cover and was quite surprised to see that it looked brand new inside. This scanner appears to have been well taken care of, despite a somewhat cosmetically unappealing exterior:
While I had the scanner open, I hit the volume and squelch potentiometers with a tiny bit of Deoxit, and the scratchiness on the output when operating them went away. The volume works smoothly across the range and audio output quality is excellent. A whole lot of elbow grease took take of cleaning up the exterior including the front panel and controls.
The next step was getting a decent antenna for the scanner - a flimsy telescoping back-of-set antenna did not work well for me inside the steel and concrete office building, and height/placement is very limited in a crowded office. Keeping with the spirit of the low budget project, I dug around my parts bin to see what I could come up with. On hand, I had a NMO bracket mount I ended up not using on my F-150 install. I sanded, primed, and painted the mount black to match the radio:
Almost there! I picked up a Laird A150/450C online for $25, and stopped by a local radio shop for a NMO mount + coax and a BNC terminal for $20. All in for $65 at this point for the Pro-2021 mini project. I fastened the antenna mount to the back of the radio like this:
The additional 2 inches of antenna height on this bracket really makes a difference! The coax is terminated with a right angle BNC => Motorola connector. Here is the final result:
It's not too pretty, but it looks OK on a software developer's desk! The audio quality and reception is great, I'm hearing distant VHF stations clearly, and the PHX ATC tower that is 2 miles from my office which could not be heard is now loud and clear inside my office. This radio will be in use for many more years to come.
