Regency H 604 Crystal controled scanner
desertman
San Diego
Any body have any info on the Regency H 604 , 6 channel crystal controlled scanner? Specifically does the scanner receive 2 meter and 70 cm ham freqs if it has crystals for these? Looks like the range is close enough but it would be nice to know before I order crystals.
Are the crystals for this scanner build around a standard 10.7mhz if?
Any info would be great.
73
Ted
W6SAT
mule1075
Washington Pennsylvania
crystals for it are 10.7 if.i know it will do from 146-174mhz.so you should be good for 2 meters not sure if it would work on 440 or not considering the uhf range is 450-512mhz.
W9NES
Indianapolis,Indiana
Regency H-604 will not cover 440Mhz .Will cover 30-50, 146-174 and 450-512Mhz and takes a 10.7 IF Regency scanner crystals.Very fimilar with that radio.I have a lot of them back in the days when we had crystal scanners.I do have 10.7 Regency scanner crystals for vhf low, high and UHF if you need them please send me a pm or a e-mail to W9nes@Comcast.net
