Regency Scanner 1st?
mule1075
Washington Pennsylvania
Could have been any one of these.
BushDoctor
Strasburg, Va
1st Regency
Does anyone know the very 1st Regency Scanner Model name and number?
In March of 1963 I purchased a Regency M-40 $99.99 it was a 12 volt DC 30 to 50Mhz monitor radio for my car to replace a Gonset 30 to 40Mhz $49.99 tuner that i wired into my car am radio in the 50s after Cincinnati and Wheeling WV stopped transmitting just above the AM broadcast band which i adjusted my AM osc.+rf amps to rx back in the 40s to the 50s Also sometime either prior or after the M-40 i bought a tunable Regency PR-155B 152 to 174MHz hi-band 120VAC and in 1964 i also bought 2 12volt crystal 6 channel crystal controlled high band regency TM-H6s. I am 80 but as i remember it the M-40 was available well before i purchased it 3 or 4 years maybe i heard California for my first time ever on it with a double skip and Louisiana State police on 39.50 all over the state as well as Rapides Parish on 39.42 as well. After CB in 1958 4W0693 i finally got my ham license in 1968 wb4igu I still have my TM-H2 and it still works on 12VDC and 120VAC and since i became a Motorola Field Service Tech after leaving the USAF in 1964 I now have antique Motorolas as well as scanners
bb911
Southern California
Thanks for sharing. I'm not quite as old as you, but I also recall some of the tunable radios. I had a Panasonic AM/FM/VHF HI radio (RF 1080) that can still be found on ebay at times.
Also, Montgomery Wards carried several tunable radios in the early 70's.
SoupBone50
Newland, N.C. 28657
tyvm BushDoctor, you have a great knowledge of scanner. I'm checking on a M-40
oracavon
Somewhere out west
Here's a chart listing the available models from a 1974 Regency brochure, if that helps anyone.
  • Chart from Regency Scanner Brochure 1974.pdf
cmdrwill
So Cali
Mine was 'dual band', VHF and low band. It had funny things inside that lit up and got hot... vacuum tubes.
scannersnstuff
Not the first, but I had the hx-1000 and hx-1200. Great scanner's. They would actually accept vhf-air, and decode it in fm,but not am. Although, I liked them, they were repair hog's.
