Bought a used 436. No upgrades with it. Plan on DMR for the 1st upgrade. Do I need to register it first in order to buy the DMR upgrade? Thanks.
As long as it wasn't already registered, it should be easy to do.Wasn't sure when it came to used radios. Thanks.
If the person registered it already - which I doubt - I think you have to call or email uniden to have them clear the other account of that serial number
The serial number (SN) should match the number on the bar code tag on the back of the scanner (12 digits). The electronic serial number (ESN) is found through the scanner's on-screen menu system, it's 14 digits and the check sum number is the 3 digits after the hyphen in the ESN.Ok guys. Just registered it. It took. But looking at my all my scanners tab, which shows my SDS200 registration, something doesn't look right. The serial number I entered didn't take the last 2 digits. Looking at my SDS200 info, the serial number is actually under ESN and some number I havent seen before is now under the SN. I did upgrade the SDS200 for DMR so thinking thats why the change. But, there is nothing under ESN for the 436. Was about to buy the upgrade for the 436 until I noticed something doesnt look right. Don't want to purchase the DMR key and it won't take. Suggestions?
You're trying to enter the ESN where it's asking you for the SN.It won't let me enter all the digits on the registration. Only 12 digits its letting me enter. Am using the SN on the screen under firmware. Can't upgrade until this gets fixed. Shot off a email to uniden.
No problem.Well DUH, figured it out. Thanks for spelling it out for me. Got hung up on digits already on the screen. Got the DMR upgrade.
