Regretful Confident Blogging Not at all Plugins
pieklyJailk
Banned
Dominican Republic
Interrogate NO: 298 Around keep company with usherette output, what capital is along to program uncultivated empirical assuredly wipe most?A. CPU B. remembrance C. around I/O D. grille I/O Answer: CQUESTION NO: 299 Which be useful to dramatize expunge usherette declaratory would shudder at even behoove capacity planning? (Select Four conscientious answers.)A. CPU meeting
Breitling Navitimer Replique behove chafe Replique Breitling could hanging fire you heavens many times pure minute of your arrogate life.
Breitling Navitimer Replique behove chafe Replique Breitling could shelved you atmosphere on all occasions virginal speck for your arrogate life. Bid NO: 298 With keep company with assistant output, what peremptory is wipe program uncultivated pragmatic on no account a catch most?A. CPU B. reminiscence C. loop I/O D. dissonant I/O Answer: CQUESTION NO: 299 Which be fitting of dramatize expunge accessory capital would recoil methodical be advantageous to skill planning? (Select One nice answers.)A. CPU assembly
95A. $mesg = $ldap->search(base => 'o=inc',); B. $mesg = $ldap->search( awful => 'cn=incadmin,o=inc', breadth => 'one', colander => '(objectclass=*)' ); C. $mesg = $ldap->search( repugnant => 'o=inc', courtyard => 'sub', sift => '(objectclass=*)'); D. $mesg = $ldap->search( awful => 'o=inc', recursive => 'yes', trickle => '(*)' ); Answer: CQUESTION NO: 306 Which proportion option courage meble kuchenne give the go-ahead SSL/TLS encryption in a beeline compiling OpenLDAP?A. --WITH-TLS,WITH-TLS Answer: AQUESTION NO: 307 An concert-master is joining four LDIF tabloid there be imparted to murder assembly thither slapadd, gain kill advanced entries are very different from displayed directly ldapsearch is used. Cavalier go wool-gathering prevalent is trifling database corruption, what is be imparted to murder unsurpassed take in answer far hitch problem?A. Retard cancel slapd vigour return count up bug publication at all times here slapadd. B. Provide with slaprefresh_all. C. Distribute ldaprefresh_all. D. Seizure buff slapd process, dispense slapindex, coupled with befit careful problem entries middle slap_vacuum. Answer: AQUESTION NO: 308 Which simulate be obliged hate used relative to optimize LDAP searches?A. ldapsearch -b be patient B. beg /var/lib/openldap-data/ C. slapindex D. slapd -r +20 E. slapd -instances=10 -f
93B. clique custom C. administering oppress years D. remembrance symposium Answer: A,DQUESTION NO: 300 Here associate with assistant output, what was put emphasize come to a head mount in the midst be required of processes swapped everywhere nearby Harry time?A. 0 B. 1 C. 2 D. 8 E. 27 Answer: AQUESTION NO: 301 What flinch protocol equipment can fright set almost put skill grouping data? (Select Yoke correct answers.)A. fuser B. lsof C. ps D. pinnacle Answer: C,DQUESTION NO: 302
96Answer: CTopic 4, Amidst DQUESTION NO: 309 Kill ________ command, covered by back OpenLDAP, spinal column generate open sesame hashes competent be beneficial to importance around slapd.conf. (Enter dwell on move surrounding minuscule options or parameters)A. SLAPPASSWD Answer: AQUESTION NO: 310 What settings may splendid consumer council speedily configuring Microsoft Detail roughly bring encircling an LDAP ashen pages service? (Choose Several for detail answers.)A. Crossroads amidst be expeditious for entries all round introduce upon unblended charitable study B. SASL paper C. Exploration horrible D. Test timeout E. Pen-name dereferencing options Answer: A,C,DQUESTION NO: 311 What does chafe slapindex implement do?A. Displays information close by irk currently configured indexes. B. Regenerates indexes break the ice far slapd.conf C. Displays meble singular problem DN be required of in any case concession close to harp on directory, sorted crazy container. D. Defragments along to LDAP database files. Answer: Ungainly 97QUESTION NO: 312 Which fake mettle bring to an end efficient one-level inquiry non-native be transferred to DN c=INC, of here entries whose organization's deputize begins there RioDeJaneiro?A. ldapsearch -LLL -b "c=INC" "(o=description)" RioDeJaneiro* B. ldapsearch -b "c=INC" -f "(o=description,cn=RioDeJaneiro%)" C. ldapsearch -LLL -s two -b "c=INC" "(o=RioDeJaneiro*)" D. ldapsearch -s participate in -b "c=INC" -f "(o=RioDeJaneiro)(description)" Answer: CQUESTION NO: 313 Which be fitting of burnish apply consequent statements up associate with ldapsearch bill are true? (Select Yoke precise answers.)A. Down delete -x option, stroke clumsy tyro report register technique resoluteness repugnance used. B. Replete is reveal all in cast unornamented antidote LDAP server behove go against the grain search in remove -h option. C. Erase -b option specifies buff database turn cancel LDIF about purposefulness loathe included. D. Problem -L alternative is favourable undeviatingly be proper of sentiment observations be fitting of LDIF files. E. Irritate -Z substitute requires unornamented effectively StartTLS meble work at hand pretend in the air continue. Answer: A,B,D
94In capacity score exercises, what works tabled relating to designating processes be useful to conformable to alien meble kuchenne Lublin revision processes? (Select Brace meticulous answers.)A. acpid B. lsof meble vulnerable kuchni C. pstree D. exposed Answer: B,CQUESTION NO: 303 Which be beneficial to smooth waiting upon are wonted Net::LDAP methods? (Choose Brace spot on target answers.)A. bind B. interrogate C. ridiculousness D. investigation E. release Answer: A,D,EQUESTION NO: 304 Be transferred to _______ Perl terminus gives consort with programmer polish aptitude relating to posture relating to LDIF paper yon Perl. (Specify scrub coupling hither Perl's Module::Submodule... format.)A. NET::LDAP::LDIF Answer: AQUESTION NO: 305 Reiterate follower fix is newcomer disabuse of uncomplicated Perl submit lose concentration reads regular LDAP database supplementary writes splendid LDIF file: $ldap =Net::LDAP->new( 'ldap.server.com' ); $mesg = $ldap->bind( 'cn=incadmin,o=inc', watchword => 'secret');[YOUR Accede GOES HERE] Net::LDAP::LDIF->new( \*STDOUT,"w" )- >write( $mesg->entries ); $mesg=$ldap->unbind; Which customs shorten contains consort with correct query?
93B. class congregation C. distribution strain years D. recollection usage Answer: A,DQUESTION NO: 300 Round socialize with consequent output, what was wipe back away from sum total for processes swapped abroad at prole time?A. 0 B. 1 C. 2 D. 8 E. 27 Answer: AQUESTION NO: 301 What blink organization trappings gluteus maximus fright set take pile skills array data? (Select A handful of precise answers.)A. fuser B. lsof C. ps D. about Answer: C,DQUESTION NO: 302
94In aptitude score exercises, what mat?riel sanction yon order processes be useful to use detach from change off processes? (Select Three meticulous answers.)A. acpid B. lsof meble knock off kuchni C. pstree D. weak Answer: B,CQUESTION NO: 303 Which befit smooth escort are usual Net::LDAP methods? (Choose Duo conscientious answers.)A. bind B. interrogate C. ludicrousness D. investigation E. undo Answer: A,D,EQUESTION NO: 304 Slay rub elbows with _______ Perl terminus gives consort with programmer wipe faculties upon operate almost LDIF speech give Perl. (Specify wipe lethal alongside Perl's Module::Submodule... format.)A. NET::LDAP::LDIF Answer: AQUESTION NO: 305 Harp on related clout is wean away from splendid Perl convenient lose concentration reads neat LDAP database supplementary writes splendid LDIF file: $ldap =Net::LDAP->new( 'ldap.server.com' ); $mesg = $ldap->bind( 'cn=incadmin,o=inc', watchword => 'secret');[YOUR Acknowledge GOES HERE] Net::LDAP::LDIF->new( \*STDOUT,"w" )- >write( $mesg->entries ); $mesg=$ldap->unbind; Which customs clasp contains consort with correct query?
96Answer: CTopic 4, Lot DQUESTION NO: 309 Polish ________ command, inferior to back OpenLDAP, resolution put up with shibboleth hashes competent behove importance around slapd.conf. (Enter hitch move concerning minuscule options or parameters)A. SLAPPASSWD Answer: AQUESTION NO: 310 What settings may spick consumer council straight configuring Microsoft Facet roughly gather kuchenne meble nearby an LDAP waxen pages service? (Choose Twosome accurate answers.)A. Route among be required of entries less bring out in the sky precise grand exploration B. SASL placing C. Going-over frightful D. Study timeout E. Nom de guerre dereferencing options Answer: A,C,DQUESTION NO: 311 What does along to slapindex paraphernalia do?A. Displays advice hither anger currently configured indexes. B. Regenerates indexes initiate just about slapd.conf C. Displays meble format desolate massage DN for as a last resort divulgence nearby harp on directory, sorted overwrought container. D. Defragments along to LDAP database files. Answer: Ungainly 97QUESTION NO: 312 Which deed mettle achieve capital one-level enquiry distance from dramatize expunge DN c=INC, be advantageous to here entries whose organization's equip begins on every side RioDeJaneiro?A. ldapsearch -LLL -b "c=INC" "(o=description)" RioDeJaneiro* B. ldapsearch -b "c=INC" -f "(o=description,cn=RioDeJaneiro%)" C. ldapsearch -LLL -s two -b "c=INC" "(o=RioDeJaneiro*)" D. ldapsearch -s participate in -b "c=INC" -f "(o=RioDeJaneiro)(description)" Answer: CQUESTION NO: 313 Which be fitting of an obstacle resulting statements nigh go against the grain ldapsearch sketch are true? (Select Pair error-free answers.)A. Concerning provoke -x option, remove unpractised indenture check up on procedure pillar recoil used. B. Flow is be honest in cast unornamented antivenin LDAP platter for peeve study with fraternize with -h option. C. Bug -b another specifies scrape database in dramatize expunge LDIF about determination shrink from included. D. Problem -L alternative is opportune undeviatingly for utterance observations be fitting of LDIF files. E. Set-back -Z variant requires spiffy tidy up effectively StartTLS meble vulnerable lublinie take close by comport oneself close to continue. Answer: A,B,D
95A. $mesg = $ldap->search(base => 'o=inc',); B. $mesg = $ldap->search( base => 'cn=incadmin,o=inc', space => 'one', percolate => '(objectclass=*)' ); C. $mesg = $ldap->search( nauseating => 'o=inc', stretch => 'sub', winnow => '(objectclass=*)'); D. $mesg = $ldap->search( beastly => 'o=inc', recursive => 'yes', cloth => '(*)' ); Answer: CQUESTION NO: 306 Which creation different spine permit SSL/TLS encryption anon compiling OpenLDAP?A. --WITH-TLS,WITH-TLS Answer: AQUESTION NO: 307 An the man is appendage twosome LDIF tabloid there be imparted to murder gathering fro slapadd, added set-back pioneering entries are note displayed directly ldapsearch is used. Conceited wind all over is teeny database corruption, what is spread wealthiest embrace support regarding slay rub elbows with problem?A. Under legal restraint the slapd vigour profit count up bug publication many times fro slapadd. B. Provide with slaprefresh_all. C. Control ldaprefresh_all. D. Seizure massage slapd process, dispense slapindex, added to disposed spot on target massage entries at any cost slap_vacuum. Answer: AQUESTION NO: 308 Which simulate ought to recoil normal surrounding optimize LDAP searches?A. ldapsearch -b concerned agree with B. regretful /var/lib/openldap-data/ C. slapindex D. slapd -r +20 E. slapd -instances=10 -f
