Relm KNG P800
cpetraglia
Fairfax, VA
I was hoping someone could guide me in getting rid of the nasty screech at the beginning of every transmission on a conventional freq. I am programmed to a local college PD and the screech is so loud you can't listen very long when their busy. I read somewhere this is some type of Moto data burst.
Thanks in advance.
mikegilbert
MHz so good
Los Angeles
Sounds like MDC1200 to me. If you have the programming software for your P800, I'd check out your signaling properties and try to enable "DOS" (data operated squelch) if available. That will mute the "screech" at the begging of transmissions.
I'm used to the Motorola ecosystem, so I'm not sure if BK offers the DOS feature on their radios.
