Relm Scanner problem
the-mace
Does any one know where I can get a Relm scanner repaired reasonably? I have an HS200 that the tn/mn button does not work and it will not go to full 200 channels, only 100. I sent it back to Relm and it was two weeks out of warranty and they returned it still broken. I searched for a repair shop and thye returned it broken because they could not find any paperwork on the scanner.
Do I throw it away? Can it be repaired? Can anyone help me?
Thank you in advance.
IdleMonitor
The Ottawa Valley - Eastern Ontario
Make sure that the other 100 channels aren't locked out. Also, there *must* be a frequency programmed into the channel in order for it to recognize it to be scanned otherwise it'll skip over them completely. Find out which channels it's not recognizing then program something into it. Ex. 26.000 then it should recognize them and then you can reprogram it.
I had that same problem and figured it out with a little help.
As far as the tn/mn problem, sorry, can't help you with that. Quite possibly it could be the keypad within the radio.
