remote antenna control & switch
stevpiz
new jersey shore
has anybody come across a reasonably priced remote mount and controlled coax antenna switch?
would like something that would cover HF thu 1.3 Ghz but so far most seem to be HF only or VHF/UHF only?
they make coax RF switches that cover this broad of a range so it would seem somebody would make a remote controlled switch with a few inputs
not looking to buy a MIL quality one costing hundreds or thousands of $
requirement is to connect 5 or more antennas to a single radio without having to bring the lines into the house or having to go outside to manually switch
would be great if it had a parallel port connector for PC control
I know, why dont I make it myself, with 4 kids I am lucky I have time to type this, would rather spend my time on the radios
N
N_Jay
Guest
Antenna switches are not cheap, antenna relays are even more.
The higher you go in frequency, the harder it is to get a good antanna switch or relay.
Good luck finding a 1.3 GHz antenna realay system cheap!
