Remote base?
vzfarms
ohio
I use 154.xxx mhz and have 110ft tower on my property that would be perfect for my base antenna. trouble is that tower would be over 500ft coax run! I can put a radio in a building below it but I am wondering if there is a possibility of using some type of remote to operate on that radio? Running multiple pair or telephone wire from the base to the office that I want to operate from is no problem.
James04TJ
A tone remote works by transmitting tones from the remote to the radio to control PTT, channel selection, PL Lift, etc... The tone remote can be wired using standard modular or UTP cable. As I think someone pointed out to you in your other thread however, setting up a tone remote requires knowledge of setting levels to be able to get it to work properly. Also, if the radio is not setup for tone control already, you will need to install a tone interface box. Gai-Tronics provides a basic wiring overview: http://www.gai-tronics.com/literature/lmrlit/gtc001002rev11-05.pdf
