Remote control APX 8000
roguexile
Is there a way to control an APX radio, or even mototrbo radio with a computer? Make it to where it can send and receive digital data through a cable interface? Using something like fldigi or similar.
a417
fldigi (or any freeware) will not work with an APX, much less a portable implementation of one.
You want hammy functions, you will need a hammy radio. The APX line is not marketed for that type of thing, nor will moto really give two fecal discharges about it.
DeoVindice
P25 Underground
Gadsden Purchase
It's doable, but calling it remote control is a bit of a stretch compared to P25 packet data functionality. You'd need a USB sound card with PTT control, such as a Signalink or Digirig, and then to build a cable that supplies the necessary inputs/outputs. Audio in, audio out, PTT, and ground are generally the bare minimum.
MTS2000des
5B2_BEE00 Czar
The only "remote control" for an APX is using an LEX-L11n as an RSM or "remote" configuration via RM/RC. As others said, these aren't hamster toys they are tools with proprietary interfaces/protocols. An amateur transceiver is the way to go for this application. Look around for an old Kenwood TM-D700/D710A, even a TM-V71A though people want a king's ransom for them now.
Outerdog
T¹ ÆS Ø
a417
was it the MCS2k that had a remote control/display via smart-rib? Only saw it once on a demo, but that was a pretty cool trick at the time.
DMS11B
Closet Nerd
Cali
XTL or XPR only on that project. No APX.
Read before you post.
Jeez bud relax a bit, it has been tested and operational on APX.
Dedgum Dawg
Maybe someone would appreciate the Intel and possibly make their own fork...
brndnstffrd
CT
Virtual Radio Control Head. I believe it worked on anything with an SB9600 bus and only needed a RIB.
Correct. I don't remember if all of the functionality and buttons worked, but I do remember running a virtual MCS2000 control head on an MTS2000 just to see if I could.
