Small to tiny Molex connector pins (like on Motorola external speakers) are a pain to remove.
There is a tab on each side (two of them) that need to be pushed in to release the pin and remove it from the body for repair/replacement. I'm sure there is a special tool, but it's always days out and you need to fix it NOW! Don't bother trying an extra-tiny screwdriver. It won't fit deep enough. Unless you are very lucky there won't be any shim material lying on your bench either.
Here is a quick down and dirty hack:
Open your plain old every day stapler and break off a five or six stables from the "bar" of staples.
Carefully break off a pair off individual staples- leave them "glued" together side by side. Cut off one "leg" to make it into an "L" shaped piece. Make another one. Slip the long ends inside the connector body to push the locking tabs in and release the connector pin. They are just the right size. Pull the pin out of the body. VIOLA!
Individual staples work too, but can be hard on your thump to push in.
This also works on PC power supply header connectors.
