Anyone try this antenna? Trying to find a good flexible whip antenna for the BT that also comes with sma connector. The Remtronix gets great reviews on the Uniden SDS100.
I'm sure it works fine on the SDS units
I'm using it on my TRX-1 traveling through Houston Texas right now it does a fair job on the TXWARN sites here there are quite a few. I didn't bring my mobile 5db gain 700 800MHz antenna this trip which works way better. But in a fixed location or walking around the Remtronix antenna is the best for scanners for 700 800MHz because of it's high gain
You can't go wrong with it
I use the Remtronix with SMA connector on my P25RX and it works very well. Better than the 850MHz Helical antenna the P25RX ships with.
Actually, the supplied telescopic antenna extended to 12" always worked better for me than the Helical. That was quite unexpected.
I'm using it on my P25RX with a right-angle SMA connector and it works well. However, I'm pretty close to the main tower in my area, so haven't tested it in a fringe area yet.
