Is there an easy way to fix this? It’s from a cheap retractable antenna wire, and the clip broke off. I suppose I could just get an alligator clip instead, but I like this one. Or, is there anywhere to buy just this part separate from the reel? If so, what’s it called?
I’ll most likely just buy another antenna that comes with the clip attachment, because I like that style of clip. I’m sure an alligator works just as well, but then I have to work at it, lol.
You could try cracking that plastic clip holder apart along the seam. Might use a sharp knife/razor blade to open it. Wire is probably just soldered to the metal clip inside there. Would be an easy fix when you got it apart and if you have a hot soldering iron, flux and solder. Superglue the plastic cover back together.
Or,
Buy a lifetime supply of replacement clips for the low, low price of $12.99:
