repair g5
HEReAZ
scottsdale AZ
does anyone know where i can turn my pager in. to get look at. i tried to update firmware and i was in the process of updating when my computer crash and turned off. once i got the computer to turn on and retried to update pager i now get an error message. i have tried to contact unication through email they first had me try a tech specialist. and we talked once but he was working couldn’t help me until he got off but that aug 13 and haven’t heard from him again. contact unication and told them of my problem and the said just reconnect the pager and just retry to update.
i did update in the past never had no issue.
pps is update before i tried to do the new firmware update. now pps, when i connect the pager to it. pps say no devices connected.
also pager will be turned off. once i connect to computer, pager screen turns on like its booting up but the pager will be turned off. so if anyone know of a place to turn pager in to get looked at. i really could use your help. thx.
also i have to pull the battery out to turn the screen off. pager is off but connected to cord see images
gilbert
N6ML
Your dealer should be able to arrange for service, especially if it's under warranty.
w2lie
New York DB Admin
Long Island, NY
Gilbert,
You may want to loop back through your Unication dealer for support.
If you can't contact your Unication dealer, you may reach out to me, I am a Unication dealer. It may need to go back to Unication for repair.
HEReAZ
scottsdale AZ
Gilbert,
i had done that thru their website and that how i got to talk with a person but he was working and couldn’t help until after work. that was aug 13th and haven’t heard from him after our first talk. THANKS FOR THE INFO. I WILL TRY BACK AGAIN WITH THE DEALER THEY POINTED ME TOO.
BenScan
D/FW
If you haven't already, unplug the USB cable you are using and try plugging it into another port on your computer, and then try the firmware update again. Not sure if that will work, but it won't cost you anything to try.
Ben
gilbert
HEReAZ
scottsdale AZ
Thanks BenScan, i had tried that. yep ur right wouldn’t hurt to try. and i re-mail the unication guy that i was appointed to me to help out.
hexagon_keyhole
Sacramento, California
"...i tried to update firmware and i was in the process of updating when my computer crash and turned off. once i got the computer to turn on and retried to update pager i now get an error message.
This is one of my biggest fears when updating the firmware for a computer, or for any device on that matter! Best of luck to you and getting your G5 repaired.
BenScan
D/FW
You might also try uninstalling the software and driver for the Unication. I don't know a lot, but I do know that the radios show up as an IP address to the software, and I suspect that might be why there's a "network error". I don't recall the particular steps to remove them. It may be easier to try installing the software on another computer that doesn't have any of the Unication software installed, and see if that gets you any further. Good luck!
HEReAZ
scottsdale AZ
Thanks i have done that, i used my daughter new computer. still no luck.
HEReAZ
scottsdale AZ
never had any issue in the pasted, but at the same time i didn’t have computer crash either.
maybe that’s why. as it’s says don’t unplug once updating is in progress.
KC3BPM
I had the same problem (network error) 3 or 4 times. I kept following the directions of unplugging and reconnecting the USB cable and after having no luck I turned the pager off.
Ok, this may sounds strange, but I attempted a while later and after I started the upgrade I realized that I forgot to turn the pager on but it updated with no problems. :unsure:
BenScan
D/FW
Another thing to try, if you haven't already is using a different cable.
w2lie
New York DB Admin
Long Island, NY
Gilbert, if you are having problems reaching the dealer that Unication pointed you towards, then send me a PM. I'm a dealer as well and would be more than happy to help you out.
