Repeater Help (BaoFeng UV-5RE)
baminian
Hello there everyone. This is my first time posting on this forum.
I've been trying to program a repeater into my BaoFeng UV-5R with no luck each time.
I found this repeater in my area: Syosset, , 447.975, WB2CYN Repeater
What should I type into CHIRP in order to be able to use this repeater (Offset, tone, etc.)
Thanks for your help!
KC9HI
First click "View" and then enable "Hide Unused Field" if not already enabled.
Frequency: 447.97500
Tone Mode: Tone
Tone: 136.5
Duplex: -
Offset: 5.00000
Mode: FM
Power: optional
Skip: optional
CHIRP Guides, Examples & Spreadsheets - see Section 6
Jim KC9HI
KK4TTR
Raleigh, North Carolina
I made the same mistake when attempting to get into a 420 MHz repeater using the 144 MHz standard offset. I was quite excited when I made my first 420 MHz contact on a repeater, after quite some time of wondering why I wasn't making it in. I could hear fine. The offset made all the difference!
Offset - The RadioReference Wiki
Chirp is a fine application for programming your UV. I have several HT's, and it helps to get them all programmed the same.
73's
KC9HI
When I keyed 447.97500 into CHIRP, it automatically set Duplex="-" and Offset="5.00000".
Jim KC9HI
baminian
I'm sorry to bump my old thread, but I'm still having problems using this repeater.
I send a transmission with one of my radios, I get the response tone from the repeater on both radios, but I cannot hear my transmission on the other radio. It doesn't pick up a signal from the repeater until after I stop transmitting on the other radio, but that signal I get after ending the transmission on the radio is just white noise.
Here is the configuration in CHIRP:
KC9HI
You cannot listen to your transmissions through a repeater with a close by monitor receiver. The very strong (because of its closeness) and off-frequency transmission overloads the receiver causing it to be "deaf" until the transmission goes away.
Miklor FAQ - 2.2
Jim KC9HI
