Repeater Question.
dixie729
Daviess Co., KY
When entering the repeater frequency how should it be entered in the CPS? 155.04000 is the main channel. 158.92500 is the repeater.
Should the repeater be entered in both the RX and TX or just one or the other?
ex....
RX - TX
158.92500 - 155.04000
or
RX - TX
CH1 158.92500 - 158.92500
CH2 155.04000 - 155.04000
WX9EMS
Lake Geneva, WI
If I am reading your post right, RX is 155.0400 and TX is 158.9250, enter them in their respective columns. If you entered it like 155.040-155.040, that would give you simplex operation.
If all else fails, read the Help file! And if that fails, let someone else do it! I am not exactly sure what these frequencies are, public service I imagine, but an improperly programmed radio can cause a lot of havoc; BE CAREFUL!!!
zz0468
Banned
What WX9EMS said.
You need to know what the TX and RX frequencies of the repeater are, and particularly, which is which. You then enter the repeater TX frequency as the mobile RX frequency and vise versa.
Both frequencies would get entered into a single mode.
dixie729
Daviess Co., KY
I think I got it.... Im going to try and upload a picture of my current CPS configuration of the the way Im understanding the input.
RKG
Boston, MA
You will do better in a repeater context if you use the terms "Output" and "Input." Together, these are the pair of frequencies used in a repeated system. Output is the frequency on which the repeater transmits (and the subscribers listen) and Input is the frequency on which the repeater listens (and the subscribers transmit).
dixie729
Daviess Co., KY
Awsome, thanks for your "input", RKG. That sums it up very well. I thought that I had it entered right in the CPS, just figured I'd get an opinion on the matter before I used it at work and it was wrong.
