Repeater question?
dustinw251
Franklinton, LA
Hope im not in the wrong forum guys but here goes. I know you cannot use 2 separate repeaters on the same RX and TX. But, in certain fire districts in our parish the transmission is very poor. Can I take and have a secondary repeater installed with a different recieve frequency and set it to transmit to the recieve frequency on the primary repeater. But yet still allowing the RX stay the same on the department radios. Several have said this cant be done because u cant use 2 separate repeaters together. or they may not be competent enough to give me a straight answer.
jaspence
Michigan
Repeaters
You can have numerous links to your repeater. Where I used to live, we had three receive towers. They were linked by an UHF system. The main tower talked and received using PL 94.8, the main link used a receive PL of 100 and relayed over the UHF to the transmitter sight. Since our assigned frequency was 147.000, we could use either plus or minus offset, so our second link received on 146.40 and use the UHF to connect to the transmitter. This does require the mobiles to have additional programming, but the system worked fine.
cabletech
Puget Sound
This is related to ham radio and just about any thing goes there.
In the commerical worls you have to be careful how you do things.
To the OP, depending on how far apart the two (three) repeaters are, yes, you can use the same frequency set up with differant input tones.
Tone one controls your main repeater and tone two controls the second etc.
When dispatch pages or talks to your people they should know that you are on tone two.
Another way is to set up a linked simlocast repeater system, but the thing with doing this is the area to be covered as you can not just set this up any where.
Hiding in a coffee shop.
I may be missing it in your message, but if you can describe the coverage issue, that would help:
Is the issue that the repeater is not hearing the mobiles/handhelds or are the mobiles/handhelds not hearing the repeater?
If the repeater cannot hear the mobiles/handhelds, then you may need to try setting up more receivers and linking them back by either RF or telco lines to a receive voter. This voter will listen to all the receivers and pick the best signal and feed it to the repeater transmitter. Another option would be to look at your receive antenna, or the rest of the components to make sure they are working and set up properly.
If the mobiles/handhelds can't hear the repeater output, then you might want to check into a single channel simulcast system. This will be expensive and requires an experienced tech to set it up.
Getting a knowledgeable tech involved would be a good idea. It takes someone with the test equipment and experience to do correctly.
zz0468
Sure you can. I see it done all the time. So long as users understand the system, particularly it's drawbacks, it can be exactly what's needed.
Yes. This can be done, but it's not how I would do it.
You can put up multiple repeaters, on the same input and output pair. Use a different PL tone for repeater access, but transmit the same tone on each repeater transmitter so the mobiles will hear any of them. Change PL tones on the mobiles or control stations to access different repeaters.
This technique works very well, and is widely deployed by CalFire and USFS here in California.
To be sure, there are drawbacks. If you want to go cheap, the technique above works well within it's limitations. If you want to tie the repeaters together, then there is several additional layers of expense and complexity involved. But it CAN be done, and can be made to work extremely well.
