RichM
- Joined
- Jul 22, 2004
- Messages
- 115
New Technician here. I have an outdoor VHF antenna with good coax on a 25’ mast. The 2 repeaters I would like to use are received with a full signal. However I cannot get voice into them on TX, just an occasional squelch tail or kerchunk. There is a fairly large hill between my QTH and the repeaters. I know my radio programming is good because I hiked to the top of said hill and was able to get in both repeaters no problem using a rubber ducky antenna. I’m using an 8w HT for both the hiking experiment and connected to my outdoor antenna. There are 2 other repeaters opposite of the hill that I can get into with full signal from my QTH so it is definitely not the radio or antenna set up.
It seems obvious to me that topography is the problem. My question is would using more wattage allow me to over come this issue? My instinct says no but the fact that I hear them with full signal and can occasionally get a squelch beep makes me wonder if it might work. I am considering trying a mobile as my base station but wonder how much extra power would help (if at all)? There are lots of inexpensive 25w mobiles available that would provide triple the power I am using now. For twice the price there are some 65w mobiles available as well. If the extra power would help then I assume more would be better?
I am hesitant to throw money at this just to get the same result. A taller antenna is not an option either. I suppose if the mobile didn’t work I could use it in the car but then I would be stuck with the power supply. What do you think?
