replace CAR STEREO with amateur radio
trx680
Petersburg, Virginia USA
I have an older car with an old school sony am/fm cd stereo. Not the newer touch screen Bluetooth satellite radio.
The radio crapped out and I'm considering replacing it with a ham radio.
It would have to fit in the space where the existing radio is. Anyone know if there are any radios the exact same size as a Sony car stereo?
NMO's installed, while-u-wait.
What size is a "Sony car stereo"?
I think if it's a DIN size, that's pretty easy to do with many radios. If it's something different than DIN, you'll need to get out a measuring device and start comparing radio sizes.
mrweather
DIN is a size standard used by automakers for decades and refers to the dimensions of the opening in the dash holding the factory AM/FM radio. Single DIN, double DIN (twice as tall an opening as the single DIN) are the main two.
AK9R
Super Moderator
Central Indiana
There's even an international standard for DIN size car stereos: ISO 7736 - Wikipedia
To the OP, if you can find an amateur radio transceiver that will fit in the opening where you car stereo was and you can figure out how to mount it, there's nothing stopping you from putting the transceiver there. But, to the best of my knowledge, there are no amateur radio transceivers specifically made to replace a car stereo.
Keep in mind that your amateur radio transceiver will generate heat and that heat will need to be dissipated. Crammed inside a car dashboard will make managing the heat a little more difficult. Also, your amateur radio transceiver will be generating RF near car electronics that may not be happy having an RF generator in such close proximity.
GlobalNorth
Fort Misery
