Good-day,
I replaced the RF connector because the center pins was broken, now the radio display is stuck on zone C and the top control A, B, and C switch has no effect, also the clear secure switch display is stuck on secure, with it's switch is not changing state either, and finally the programming for the channel selector switch does not display the data in the code plug setup. I have checked the cabling and I am fairly certain it is correctly re-installed. Whatever help you could provide would be appreciated. Thanks in advance.
