Replacement parts for the Pro-83?
Zack08
About two years ago I bought a Pro-83. I used it for a long time without a proper case for it. It still works well, but by now, it has quite a few noticeable scratches in the paint. Does anybody know if it is possible to order new plastic pieces for the front and back any maybe a new keypad? Anybody know of a price for those pieces? Im proud to say that I have since kept my other scanners in better condidion :), but I'd like to have this one look new again.
Thanks in advance!
jrplmil
pro-83
have you tried the pro-83 forum on yahoo? good luck
Bentley
Freehold, NJ (Monmouth County)
If you call radio shack at 1-800-843-7422 you will be able to order any piece for your radio you'd like, including the keypad. I dont know what the prices are. I cant imagine they'd be that expensive though.
Dont go to a store to order the parts....I HIGHLY recomend calling instead. I dont even know if you can order parts from a store.
KLH
Indiana
If I remember tomorrow when I go to work I will look it up for you.
You can order parts through the store, but to be honest, most employees don't know how to. Those that do know how to usually don't know how to look it up online to see what parts are available and the RSU #'s and prices, and they end up calling the order center to ask for the part numbers.
If anyone ever wants to know what parts are available, just go to a store and tell the associate to go to Answers Online > Products > RSU Lookup, and type in the SKU # for the scanner you are wanting to order parts for. Then ask them to print it out for you.
austinscan1
pro-83 parts??
Before you replace parts check prices. You may be better off buying a new radio for 69.97 while the're still out in stores. Austin
Zack08
Thanks for the tips, guys.
"most employees don't know how to. Those that do know how to usually don't know how to look it up online to see what parts are available and the RSU #'s and prices, and they end up calling the order center to ask for the part numbers."
Yeah, I wanted to check the prices of parts for another scanner a year ago and it must have taken the employee about half an hour to even figure out how to look it up.
I'll give it a couple of days and see if anybody here can come up with prices. If not, It looks like I'll either call them or visit the local store.
KLH
Indiana
Here is the list of parts available. Sorry for the bad formatting.
Code:
RSU # Description Sug. Retail Availability Additional Description
12374880 XSTR 2SA1235A SC59 S $2.49 In Stock
12374898 XSTR 2SC3052 SC59 S $2.49 In Stock
12424701 ANTENNA HIDAKA AT-465 $10.89 In Stock
10575793 CAP CER 1000PF +-10 50V $2.49 In Stock CASE STYLE 0805 PKG OF 5
12424859 CRYSTAL QX-815 20.85MHZ $3.89 In Stock
12424685 COVER BATTERY ABS $2.49 Not In Stock
12429049 DIODE ZENER UDZS6.2B TE-17 $2.49 In Stock
10681344 PLATE,SPRING KNOB $2.87 In Stock
12424727 SCREW BIND HD + M2.6X8 $2.49 In Stock
12424693 KEY RUBBER SI $2.49 In Stock
12424719 CLIP PC $2.49 In Stock
12424362 HARDWARE KIT 20-501 $2.49 Not In Stock CONSISTS OF: SCREW P TIGHT BIND HD + D2X6 NI QTY 6 SCREW P TIGHT BIND HD + D2X8 BZMC QTY 2 SCREW P TIGHT BIND HD + D2.0X14 BZMC QTY 4
11275351 JACK,SPEAKER 2 PIN $2.49 In Stock
10725372 JACK,ANTENNA $5.89 In Stock
12424875 JACK DC JK-1155 HOSHIDEN $2.69 In Stock
12424867 LCD JIC DL-306 JIC-TR3706P $5.49 In Stock
12424370 MANUAL USERS 20-501 $4.99 In Stock
12087151 IC 24LC16BT/SN SO8 S $7.38 In Stock
12430963 POT VAR RV941 RY7639 $7.29 In Stock
12430971 POT VAR RV940 RY7638 $7.29 In Stock
12424677 SPEAKER DETAI SP-407 $2.49 In Stock
11646940 IC,UPC8112T-E3 6 PIN $8.75 In Stock
12424354 REAR ASSY $4.49 In Stock CONSISTS OF: CASE REAR(COMP) ABS SPRING TERMINAL SWP KNOB ABS SPRING PLATE KNOB D6XL5.2
Zack08
Looks like everything I want is well within my price range!
Thanks KLH!
