stingray327
stingray327,
The 48 MB & 80 MB is the cards bus/interface max transfer rate.
The SD speed/load time debate is going on in both the GRE/Whistler and Uniden camps. The real question as to how fast is most likely dependent on the rated speed of the SD interface in the scanner.
There are two speed ratings, Class and Bus. Class ratings are minimums so Class 10 is a rating of a minimum of 10 MB/s. The Bus ratings (today) are maximums listed as UHS.
UHS 25MB/s
UHS-I 50MB/s with a 4 bit bus
UHS-II 156MB/s with a 4 lane bus
Look for the Roman Numerals I or II next to the SD card logo.
Last but not least there's the USB data transfer rate which is listed as megabits per second. So USB 2 is capable of 480 Mb/s which is roughly equal to 48 MB/s (megabytes).
I haven't seen any information regarding the SD Bus interface speeds for scanners. If I had to take a guess I would say USB 2 speeds 480 Mb/s (a.k.a. 48 MB/s), since a USB 2 cable is provided by the scanner manufacturers.
So at this time the max for these Uniden scanners are 32 GB Class 10 with 90 or 95 MB which are the most up to date SD memory cards you can get that will make a big difference from any other 32 GB SD memory card.
