StiCo makes a substitute antenna for the "shark fin" antenna cut for various two-way radio frequencies, such as 136-174 MHz, 440-469 MHz. a dual-band utilizing both of the aforementioned frequencies, plus another set of multi-band "shark fin" substitutes that include the 700-900 MHz spectrum. I may not have the exact frequency ranges for the exact StiCo antennas, but they are *VERY* expensive. Plus, another install tech told me that the splitter they have as an accessory doesn't work well, bringing back typical AM-FM broadcast reception. He suggested NOT using the splitter for the broadcast radio, rather running a wire, usually running around the front or back windshield, and connecting that to the AM-FM broadcast radio. They make a specific adhesive-backed wire antenna for these purposes. You'll get in a bind if you have Sirius/XM because that needs the "shark fin" cut to the satellite frequencies, or it just won't give you proper reception. StiCo also makes magnetic-mounted versions of the above-disguised models, but we all know about the disadvantages of "permanent use" of magnetic-mounted antennas.
All this rigamarole can get expensive for the parts, plus labor for an experienced tech to install all or some of the above.
