DSDPlus Request help, possible verbosity issue?
rrbum
When monitoring a P25 phase 2 system I am unable to see the affiliation/registration requests.
If I use SDRsharp and pump the audio data into a running instance of DSD+ I can see the requests and grants. But, when using FMPA for CC and VC with two airspies I no longer see this info. I see the calls fine, but not the registration or affiliation data.
I am not sure if this is due to a verbosity setting or if this data is not available using the FMPA link to DSD+.
Anyone using FMPA linked to DSD+ seeing the aff/reg information?
Hoping someone can set me straight on this issue. Thanks.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
I run two Airspys, in trunked configuration (2 FMPA + 2 DSDPlus). I run -v4 verbosity on my DSDPlus. No issues with registrations. NOTE: You are going to see the reg/affil only inside the CC-DSDPlus copy and not the VC-DSDPlus copy.
rrbum
OK. Thanks for reply. I set my DSD+ to -v4 and still not seeing the reg/affil data. Just calls and neighbor info. I must have some setting wrong somewhere. I switched over to another instance of DSD+ fed from SDRsharp and saw plenty of reg/affil occurring.
Glad to know that the data should be there. I just have to find out now why I am not seeing it.
mtindor
OH/WV DB Admin
Don't put my trust into what I posted. I didn't read your question thoroughly. I posted a screenshot from a PHase I system. I have no Phase II systems to monitor, so I can't say if it's working for me. Sorry to have jumped in before I read your question in its entirety.
Hopefully somebody else will have the answer for you.
Mike
rrbum
I found it !! Posting in the event someone else may encounter same issue some day.
The "B" option of show/hide background events was set to hide. By cycling through the options using the "B" key and setting to show all events fixed my issue. Live and learn.
mtindor
OH/WV DB Admin
That's great! Thanks for sharing
u2brent
OAMPT
KRWDPAXKRS1
Now if we could just get those same messages on CON+ systems.. :)
Maybe they don't operate like that, or DSD+ just doesn't decode those CC messages?? IDK :unsure:
