- Joined
- Feb 2, 2022
- Messages
- 23
Hi all. While making my omni-directional vertical FM broadcast band antenna from the end section of a Winegard antenna (the unused VHF-Lo part which I cut to 97 MHz), I read that stick dipoles have a native impedance of about 75 ohms, while a folded dipole has an impedance of about 300 ohms. Is this correct? I took a 300 to 75 ohm balun and modified it to become an F female to twin lead adapter, just making a cleaner junction than taking the RG6 center conductor to one leg of the dipole and the shield to the other. I'm also asking because I've seen the same design from Winegard and now from Channel Master (except they design it to be horizontal, with Winegard using an additional opposed dipole), and both are using 300 to 75 ohm baluns. Which is correct? Is the stick dipole 75 (ish) ohms, or 300?
Thanks for any info.
Ed
Ed
