Hello,
The topic pretty much spells it out. When spring arrives I have a tower mounted project in mind for an 800 MHz yagi which will be mounted on a side arm L type bracket with a lightweight rotor. I normally don't use preamps but I want to give one a try to maximize DX reception on this band. I've tried doing some research on inline and/or mast mounted preamps that are powered on the coax by a power injector. The antenna will potentially be used by multiple receivers/scanners and as such won't benefit from the bias tee output of an Airspy or RTL device.
Obviously I'm looking for the lowest noise best bang for the consumer buck solution specifically for this band. I did find the Stridsberg 700/800 preamp. I can weatherproof with the best of them but I'm not sure that this would be the best option. We have discussed that Stridsberg devices work well but don't have the lowest noise figure; this one shows a 3.5 dB noise figure and 18 dB gain. Something that is completely inline on the coax run would be ideal, but at least something that is built to be mast mounted would work. I do have a five site 800 MHz simulcast analog TRS here and a forthcoming multi-site Phase II P25 system to consider as possible contributors to overload, but hopefully the fact that the antenna will be on a rotor can minimize some of that if it's an issue. Most of the radios that will be in use with this antenna have variable attenuation, to include an IC-R8600 and numerous SDRs.
I'm continuing to search but any constructive suggestions would be appreciated.
Thanks!
Thanks!
