Rescue 21
Railbender
NW PA
When programming my 396XT for the USCG Rescue 21 (LMR) frequencies is each frequency entered as a single-frequency P25 system or are they considered a standard P25 trunked system?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Neither. These are simply conventional freqs that use P25 digital modulation. Be sure to set the audio type to 'digital'. I would also allocate another channel with the same frequency as an analog channel using FMN (FM Narrow) as I understand at least some of these channels are not exclusively P25
Mike
ecps92
Taxachusetts
The only reason to program them as Single-Frequency Trunk is to log/track the Radio ID's.
Otherwise you just program them as P25 conventional
And as Mike indicates, some of those frequencies are shared, as well as still in-use in Analog Modes by the USCG
