boondockdad
I've been told this is a very contentious topic with a lot of federal precedent in the ham's favor, but I searched and wasn't able to find any relevant threads so...
My city's ordinance states:
(a) Antennas with a wind-resistance surface of seven (7) square feet or less shall be located in the rear yard or on a rooftop, provided that freestanding antenna towers shall be set back from all property lines a distance equal to the height of the tower. Such antennas shall comply with the height standards for the district in which they are located, except as hereinafter provided.
(b) Antennas with a wind-resistance surface of over seven (7) square feet shall be located in the rear yard only, and shall be subject to the setback and height standards for the district in which they are located. Any such antenna shall be located to obscure its view from adjacent properties and roads, to the maximum extent possible.
(c) Notwithstanding the above requirements, open element and monopole antennas shall be permitted in residential districts, provided they do not exceed forty- five (45) feet in height.
My interpretation is: I can put up a vertical antenna up to 45' high on my roof, but it has to be 45' vertically from any of my setbacks.
Clearing my setbacks by 45' is going to be a problem. Actually, 8' would be a problem.
I understand the reasoning, but it seems unreasonable since the actual structures on lots themselves aren't constrained to 'fall over' setback requirements. ie. chimney's or even the building itself. How about trees? My neighbors dead maple tree would demolish half my house if it decides to fall my way.
As an architect, I've dealt with variances in this municipality before and let's just say getting one's highly unlikely (unless you were willing to grease the right palms).
Any advice or links to good overriding precedent?
