Restoring 2055
gsxr4000
Does anyone know the way, or is there a way, to restore the 2055 back to "factory settings". I want to totally wipe it clean and re-start with it the way it came out of the box brand new.
Does anyone know how to do this or if it's possible?
Thanks!
DaveIN
Founders Curmudgen
West Michigan
1. Turn off the scanner, then turn it on again. Multi-system Trunking Scanner appears.
2. Press 0 while Multi-system Trunking Scanner appears.
3. Press 1.
4. Press ENT. Initializing please stand by. appears for about 5 seconds
Note: Do not turn off the scanner until the initialization is complete. When the initialization is
complete, M000 appears on the top line of the display. Bank 0 Ch 00 appears on the third line.
rdhamr309
Thanks!
There"s a section called initializing.This will wipe out all info on your scanners working memory.
1.Turn off scanner and turn on again.Multi system Trunking scanner appears.
2.Press 0 while Multsystem Trunking appears
3.press 1
4.press ENT. (Initializing please standby)appears for about 5sec.
5.DO Not turn off scanner until complete.When complete(M000 andBank 0 Ch 00 appear.
REMEMBER THIS WIPES OUT YOUR SCANNERS COMPLETE MEMORY
