Restoring an XTS3000 to factory default
Does anyone know how to restore an XTS3000 to factory default? Thanks!
alternately, you can use clone wizard/clone express in CPS to clone in a codeplug from an IDENTICAL radio with the EXACT flash code/feature set.
Yeah I just got a new radio and I want to wipe it clean, like a brand new radio
Project25_MASTR
TX-COMU
Texas
Better off just deleting everything but one trunking personality and one conventional personality, list, etc add new ones and delete the remaining of the originals.
Is there a wizard like on the Astro 25 CPS? I'm trying to get rid of all of the trunking personalities
sfd119
No, just delete the personalities and move on with your programming.
Thanks! Also is there a way to upgrade the flash code so I can get ID display?
FFPM571
The Mid South
Not with the software you have...It takes Lab software and that is not something for beginners to play with..
Lol not a beginner. I have 10 xts5000. I'm just new with the older and slower radios
Project25_MASTR
TX-COMU
Texas
There's a program floating around called FDB Tool (or something like that) but if the firmware is new enough (and not analog only) you can change the flash code options via the SREC. Let me more clearly re-iterate that...the firmware has to support the options you are enabling in the flashcode. So if you have an analog only firmware, you can't just enable P25 in the flash because your firmware doesn't support it or if you have a digital radio and enable 9600 bps trunking but don't have the firmware to support 9600 bps it won't work.
