horizon1015
I am trying to re-use a Dish TV mount as an antenna mount for a discone antenna used to feed a scanner. Because of the height of the antenna, I cannot just attach it directly to the mount, I need to add some additional masting. The problem is, I can't find a way to attach additional masting. The OD of the mount is 1.66 inches, which appears to be the same as galvanized fence posts but I cannot find a coupler. I would also be happy to use a larger or smaller diameter mast pole that would fit inside or outside the existing mount pole.
I would prefer to keep costs down as the feed is just something I do for fun, any ideas/suggestions?
Thanks!
Thanks!
