Baofeng Reverse Burst On Baofeng DM-1701
FoxMcCloud
I just programmed my DM-1701 with an analog channel with CTCSS 67.0. There is a squelch tail at the end of the transmission, I checked the box that says 'Reverse Burst' in the CPS software. And set the QT reverse to Silent, there is no change to the squelch tail.
nd5y
Wichita Falls, TX
That's not really reverse burst.
Baofeng and some other CCRs send a 55 Hz (or other frequency) tone for about 250 mS when you unkey.
If you need compatibility with real CTCSS phase shift reverse burst then don't be surprised if it doesn't work poperly.
FoxMcCloud
Ah I didn't know that. It works on my Motorola HTs and my vertex mobile radios. I was reading that the DM-5R jams up both timeslots, do you know if that true with the DM-1701? If not I'll start a new topic.
nd5y
Wichita Falls, TX
I don't know how the DM-1701 behaves on DMR or FM or anything else.
The reason your Motorola and Vertex radios appear to work with Chinese STE is because the time it takes to close the squelch when CTCSS tone is lost is shorter than the time the Baofeng transmits the 55 Hz STE tone.
Not all radios are like that. Some won't mute until up to several seconds when the CTCSS is lost.
