Alinco: Review: Alinco DJ-500T (2nd Generation)
baayers
Pinellas County FL
It's actually pretty good. I like the look of it too. I don't see a need to replace/upgrade it for now. I tried one of those $10 17.7" antennas from E-Bay but it was too long for practical use.
Unfortunately, Laird quit making whip antennas for portables. You can always buy the Motorola antennas though since the DJ-500 uses the SMA-Female connector. (For single-band usage.)
Here's a pic of the Motorola UHF antenna on the DJ-500 and the DJ-500 antenna on the Motorola. It looks cute:
Here's a place to buy the various single-band antennas if you get curious:
Motorola XTS 5000 Portable - ShopWiscomm
Oh I forgot that Motorola makes a dual-band VHF/UHF for their APX 7000 series:
PMAT4001A PMAT4001 - Motorola APX Dual Band Antenna VHF UHF GPS - ShopWiscomm
Kind of pricey but I may give that a shot for fun.
I am thinking about getting this radio but had a question for you? Does the radio have the male connector like the Baofeng or the female like the Yaesu / Uniden scanners. When you mentioned the female connector I wasn't sure whether you meant on the antenna or the actual radio.
Thanks in advance for your answer.
SMA Male. It uses the SMA Female antennas.
baayers
Pinellas County FL
I just ordered a 500T from HRO this morning so I am looking forward to getting to know this radio.
Also thanks John for your earlier comment on the cable. I found it and saw your review so I know I am getting the right one. Since 7 found the driver automatically I hope 8.1 will do the same. If not I see me spending a bit of time this weekend on my 7 laptop.
kd4sas
Programming DJ-500T 2nd Gen
I have the cable, but the Alinco program does not find the radio.
Do I plug the cable into the Ear jack?
Do I put radio in the clone mode?
I selected the model, and the com port. I am using the OPC 478 cable.
Any help would be appreciated.
remtronix
Hayward, California
Make sure you select the correct Model "DJ-500T" If the problem persist, contact us at 510-298-5100 and ask for Tech Support
N8IAA
Fortunately, GA
Silly question, have you actually read the manual to see how to connect to the software? You're asking questions that can be answered by doing this simple thing.
Larry
wb7ond
Fayetteville, NC 28303
DJ500 Programming
I am sorry to have disturbed you, the software has only a HELP->ABOUT, the DJ500 manual does not seem to have computer programming as a section.
Again please excuse me, this was my first time at this forum, I will seek help elsewhere in a more novice forum...
Regards
wb7ond
wb7ond
Alinco DJ500 Programming
Raj from Remtronix (sp?) Alinco Tech support was super helpful, and got me going. If you need help with an Alinco HT they are the folks to help. Thanks again RaJ...
Regards
WB7OND
remtronix
Hayward, California
Regards
wb7ond
wb7ond, I would personally suggest you utilize 3rd party RT System program. Its developed in USA with better interface and easier to us.
That said if you need further assistance, please contact us at 510-298-5100 PST M-F
towerk
I'm using the OPC-478 cable and the software can see the radio, but the setband app to expand the freq range won't allow me to set the expanded range.
That doesn't seem to be a cable issue. I can read radio with the setband app as well.
Any thoughts?
Keith
K3KPH
towerk
Has anyone successfully expanded the TX range of the DJ-500T?
Getting frustrated and may sell the unit.
Keith
K3KPH
towerk
Thanks for the cryptic answer that doesn't help anybody. I'll infer that it's the cable and that you've successfully expanded the TX range with that combination. It's never confirmed anywhere in the thread.
Typical non answer that permeates this forum and gives hams a bad name
Thanks for nothing.
AK9R
Central Indiana
It would be cynical for me to say "Typical hand-me-a-cookbook-for-doing-exactly-what-I-need-to-do-because-I-don't-have-time-to-research-it-myself" question that we often see from new posters in this forum..so I won't say that.
If you read through nickcarr's posts, you will find your answers. Nickcarr owes you nothing and has already posted some very useful information about this radio in this thread. Whether or not he chooses to help you is up to him.
ae4x
Satellite
Anyone know if these would work way for the birdies?
73, Rob. AE4X
73, Rob. AE4X
Yes the sub-display can show your Rx 70cm downlink frequency and the main band will be the Tx 2m uplink.
For speaker audio, the main band frequency takes precedence. So the only catch is that if you heard someone locally on the 2m uplink frequency then you won't be able to hear the 70cm downlink audio.
Obviously you'll need some kind of directional antenna as well. (The Arrow antenna would work well with a SMA-BNC adapter.)
zwoerdkop
There are no sources to be found in the whole wide world that could probably answer the two extremely intelligent questions of kd4sas:
1. In which hole do you have to pound the programming cable in, the ear jack or the microphone jack?
2. Do you have to use the CLONE mode?
kd4sas was accused for asking 'silly questions' and advised to RTFM.
But: the question is still unanswered!
So who dares to answer the Two Holy Questions after all?
Thanks!
towerk
The cable only fits into the earphone jack. It's the thicker of the 2 connectors on the typical kenwood cable.
In my experience, when using Alinco software, the radio automatically goes into and out of cloning mode then resets the radio immediately after.
Liking the radio so far, battery life is suspect but I'm not drawing conclusions just yet as I've only had to pwer drain cycles on the radio.
