JHaislet
I just got the Maldol MH-255 SMA "Active Hunter" in today. It is a very flexible ducky; size-wise, it fits the 396T extremely well and is exactly HALF the length of the stock Uniden ducky. There are no markings on the MH-255, so it would probably be difficult to tell the difference between it & it's 2M/70cm sibling, the MH-209 SMA.
So far I am very pleased. It picks up all the local 159MHz VHF P25 traffic with a full five bars (to be expected since tower is rather close). There hasn't been enough conventional traffic on the distant site I was trying to compare, but will update when I get a chance.
Note: The following comparison is done using two NOAA stations: (1) 162.500MHz & (2) 162.475MHz. Site 1 is about 28 miles away; site 2 is about 48 miles away. These were chosen as they continuously transmit on a frequency extremely close to the range I needed the MH-255 for.
The numbers below are by no means scientific, so take them as such. They're my observation of the signal strength bars on a BCD396T and my perception of how clear the channel/antenna combo sounds. YMMV!
While the signal strength only displays whole numbers, I've converted them to decimals to portray approximately how long it stayed at that level. For example, 1.5 means the signal evenly fluctuated between 1 bar & 2 bars.
-162.5 & 162.475 MHz--Site 1-------Site 2-----Length(inches)-
Maldol MH-255SMA----3.75--------1.5-------2.85-------------
Uniden Stock SMA------3.25-------0.75-------5.68-------------
Pryme RD-9-SMA-------2.0---------0.25------7.68-------------
RadioShk 800BNC-------3.0--------0.75-------7.43------------
Maldol AS-25SMA------0.25--------0.0-------1.00------------
(Interestingly, while the AS-25 usually didn't show a signal bar, the audio was extremely clear and probably coming in at ~80-85% (I could easily understand the broadcast, with very little static or popping).
The MH-255 now makes the 396T extremely portable for my purposes, all without any perceivable loss in signal clarity for the VHF frequencies needed.
I hope this has been helpful to those looking for a small VHF antenna.
(from left to right: Pryme RD-9-SMA, Radio Shack 800MHz BNC w/SMA adapter, Uniden 396T stock SMA, Maldol MH-255 SMA, Maldol AS-25 SMA)
