- Joined
- Jul 22, 2013
- Messages
- 68
This is lifted from an off-shore review of the H501x, its quite instructive and it indicates, to me, my radio is not a one off damaged unit, but rather the condition is endemic to the specific DSP chip used in the series, keep this in mind if you are thinking of buying this radio, if just for program listening you'll likely never even know this issue exists, if you're a MW/utility DX'er this indicates, exactly as I have found, that you really cannot zero-beat(calibrate)the radio on the SSB's across frequencies. That means if you zero beat the radio on the MW it will largely be zeroed on the MW, but not in SW, or vice versa.....
When I first received the H501X, the 25-meter band from medium wave to short wave seemed to be very accurate.Further tests showed that: it is necessary to recalibrate the frequency, but the deviation of the 19-meter band from medium wave to short wave is not as obvious as I saw on the PL990X. Re-calibration at the center frequency of the 25-meter shortwave band seems to be a great midpoint for calibration. However, it is inevitable that the frequency calibration of the short-wave band will cause the mid-wave frequency to deviate a bit.
